84 eats starters
Old Mar 31, 2011 | 02:00 PM
wgaffney85's Avatar
wgaffney85
Hey mike this wes if you like you can give me a call at 859-325-0481. Im located in Harrodsburg, KY. I can call the Napa store and try to find out the part number. By the way I tried the shims, I tried everything and any Ideal someone had. Nothing worked until I came across that starter
Old Mar 31, 2011 | 04:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by buffy.mike
i bought the 351W long block off of craigslist. The previous owners said that they bought it for their 71 Mustang.
EOAZ-6375-A (replaced C5AZ-6375-T) .. Flywheel (flexplate) / Ford just obsoleted this part.
Original specs for C5AZ-6375-T = 164 tooth ring gear / (4) converter attaching holes on an 11 7/16" bolt circle.
This EOAZ-A/C5AZ-T flywheel fit myriad 289/302/351W/351C applications from 1965 thru 1996, should be able to find one at any parts store.
Old Apr 3, 2011 | 11:16 AM
buffy.mike's Avatar
buffy.mike
wes i got the ten tooth starter put it on the truck starts like a dream ,i meen its never started this good before thankyou so much for your all your help ,
Old Apr 4, 2011 | 05:13 PM
buffy.mike's Avatar
buffy.mike
fixed
wes just wanted to let you no the starter works perfectly thankyou so much you probally saved the truck from the salvage yard, once again thankyou for all your help
gary's1950F1
Feb 27, 2016 12:39 PM
NDChris
Mar 13, 2015 10:01 AM
paddler
Mar 15, 2014 01:01 PM
EWHOLTZCLAW
1978 - 1996 Big Bronco
Jul 25, 2011 09:56 AM
