cab heater
Old Mar 17, 2003 | 09:54 PM
gog68's Avatar
gog68
cab heater
does anyone know anything about
"eaton auto heater model 55-105 12v" its whats in the cab of my project truck and i was wandering if it was a upgrade heater or an after market one.
parts repair / rebuild advice as it currently is not working and i cant see putting in original heater as this is such a neat and small unit, if working.
thanks for any help
gog
59 f100 long bed 223
60 f100 short bed 292
Old Mar 18, 2003 | 10:54 PM
angus's Avatar
angus
cab heater
It sounds aftermarket to me.
What's wrong with it? If the core leaks, replace it if it's corroded, or patch it if it is frost-split.
If the fan doesn't run, find out if it's the motor or the wiring to it (or the switch). If the motor is dead, scrounge a similar one from another heater.
Old Mar 19, 2003 | 08:59 AM
GreatNorthWoods's Avatar
GreatNorthWoods
cab heater
Angus,
Since you brought it up. How would you go about finding a replacement core for an aftermarket heater? I have one, but not sure how good the core is. I'm hesitant to use it unless I can find a source for a new core...
Old Mar 19, 2003 | 10:05 AM
Midnite Cruiser's Avatar
Midnite Cruiser
cab heater
I have a compact aftermarket unit also that I replaced with a stock unit . Core Ok. Has 2 fans that I could test if you are interested.
Old Mar 19, 2003 | 10:35 AM
GreatNorthWoods
cab heater
Cruiser,
I keep yours in mind if I can't find a heater core. Is it 12 volt? Thanks.
Old Mar 19, 2003 | 11:34 PM
gog68's Avatar
gog68
cab heater
thanks for the input, its a bad core.
tried soldering but it didnt hold. went through the shelves at the local checker but they had nothing just right.
gog68
Old Mar 20, 2003 | 03:27 PM
angus's Avatar
angus
cab heater
Greatnorthwoods:
If you can't track down the original manufacturer and get a replacement through them, a radiator shop could make up a new core for you (for a price...). Or, hunt around the scrap yard for a core which can be persuaded to fit, maybe by splicing the pipes, or cutting some different holes in the heater case.
Or if you want a like-new aftermarket heater, buy a new one. There's got to be some models that haven't changed since the 1950's.
