Frame widths
Old Mar 29, 2011 | 10:11 PM
scappoosefordman's Avatar
scappoosefordman
Frame widths
Will a 2wd 70 f250 body go on a 4x4 70 F250? I was told the frames are different but when i measured the bolt in the bed of my 4x4 and then the same bolts in the 2wd the were the same distance apart. I am askin this because i was debating on puting my 4x4 body on a 79 4x4 frame. My friend said i would have to use a 2wd body or drill new holes in mine. Is that correct?
Old Mar 29, 2011 | 11:01 PM
Rogue427's Avatar
Rogue427
79 Frame is a little longer. Forget how much but its been done before.
A 70 frame would be easy.
Old Mar 30, 2011 | 02:01 AM
RichS2659's Avatar
RichS2659
Read the previous post, 72-79.
Old Mar 30, 2011 | 04:14 AM
jowilker's Avatar
jowilker
Frames are different, but there are no 2wd & 4wd bodies, mount points are the same.
To your question, yes.
John
Pronk
Oct 11, 2013 08:42 PM
lemonshindig
May 21, 2010 12:30 PM
BMG50Sniper
Jan 20, 2010 02:02 AM
jstandle
Sep 24, 2006 07:11 AM
koto
Nov 1, 2000 10:40 PM
