Dual Battery Question
In theory, if each one is rated at 600CCA, you get 1200CCA combined
Why 2 on diesels? They've got to supply enough juice to keep the 8 glow plugs running long enough to heat up and then still have enough juice left over to crank the engine at the same time.
If a typical glow plug draws 150W, that works out to about 12-15A each. Multiply by 8 cylinders equals over 100amps of current that's got to flow while the engine cranks. A single battery probably won't last very long trying to turn over a frozen engine.
Dual alternators are also wired in parallel. The output capacity is the sum of the two. It's probably more efficient to have 2 do the work of 1 huge alternator of equal capacity. There's also the economy of scale... Ford only needs to spec one standard alternator and use more of them instead of spec'ing two
different units
I seem to see some camper setups using isolators among several batteries...that's done to share the alternator and prevents draining the main battery(ies) used to start the engine.
Side note--I think our factory batteries are 600-something CCA's. Technically speaking, if a single Optima battery can supply the same CCA's as the 2 factory batteries, we'd only need to buy one of them and shave 50lbs off the truck. Put two of those guys in and you can turn over a 747 jet engine.
Optima batteries seem to be rated at 800 CCA from what I can find, I'd be interested to see how they do on a frozen engine.
