Sponsored by: Kumho
Tire size
Old Mar 29, 2011 | 02:45 PM
pooter's Avatar
pooter
Tire size
<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> I have a 1999 F-150 4x4 Sport. The factory tires that came on it were 265/70R17. I am going down to a 16" wheel and I was wondering what was the biggest and widest tire I can put on it? I do pull a camper and it squats the rear end quite a bit. The tire guy suggested a 265/75R16 tire. Can I go bigger without rubbing, or will these tires look good on it? I want as wide as I can get but not rub while pulling my camper.
Old Apr 16, 2011 | 03:33 PM
KrautBurner's Avatar
KrautBurner
you can probably go 285/75's
depending on your wheel offset.
each truck sits a little different, so, you may need to test fit one up front to evaluate.
