AOD to ZF conversion
Old Dec 20, 2002 | 05:23 PM
marragtop's Avatar
marragtop
Old Dec 22, 2002 | 07:40 PM
mjb1962's Avatar
mjb1962
Anyone with information on how to convert an AOD automatic to a ZF manual transmission? Vehicle is an 89 F150 4x4 302 V8. Any info would be appreciated.
Mark
Old Dec 22, 2002 | 09:05 PM
masterbeavis's Avatar
masterbeavis
The first think you have to do is find the tranny, flywheel, and clutch pedal assembly. I would imagine then you would need to have your computer modified to not try and control the electronics in the automatic tranny. Alot of grief is involved. It is easier IMHO to just buy a truck that already has the setup you want. The swap can be done, tho it is easier to buy a wrecked truck and have the whole donor vehicle so you can have every part you might possibly need.
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old Dec 22, 2002 | 09:20 PM
steve83's Avatar
steve83
The AOD isn't electronic, so there's no concern with the computer. There will be a LOT of labor involved in adding a clutch pedal under the dash and fitting the driveshafts, but it's probably worth the trouble. I'm looking to go from an NP-435 to a ZF.
Old Dec 26, 2002 | 04:55 PM
mjb1962's Avatar
mjb1962
Sounds like a good idea to look for a donor vehicle at the junk yard that has all the components for the swap. Thanks for the help.
Mark
