New intake boot?
Old Mar 27, 2011 | 01:28 PM
JT250's Avatar
JT250
New intake boot?
My boot that connects the filter tube to the ccv delete is badly weather checked here can I find one. Looked on flea by a little and didn't see one
Old Mar 27, 2011 | 01:42 PM
JOHN2001's Avatar
JOHN2001
Ford F250 Truck F Series Pickup Excursion Intake Hose with 7.3L Diesel Engine at 1AAuto.com.
This the one your looking for?
Old Mar 27, 2011 | 01:50 PM
JT250's Avatar
JT250
No it is rubber. I am assuming that I would replace it w a silicone one. Maybe it's not stock it had a different intake on it when I bought it and I put the aFE II on it. Probably could use an intercooler boot.
Old Mar 27, 2011 | 01:52 PM
JOHN2001's Avatar
JOHN2001
Do you have a picture of your set up? That would be a big help
Old Mar 27, 2011 | 04:01 PM
JT250's Avatar
JT250
I'll have to track it down later I'm puttin the truck back together right now had to put new o rings on the injectors
Old Mar 27, 2011 | 04:07 PM
JT250's Avatar
JT250
http://http://afepower.com/shop/details_new.php?partno=54-10192&diesel=true&menu=diesel&searchtype=make&make =ford&&brandID=53
Don't know if that link will work, but if u can click on it it is the boot in the middle pic
Old Mar 27, 2011 | 04:28 PM
JOHN2001's Avatar
JOHN2001
Thats straight from AFE you could try to give them a call an see if they would sell you just that part, or even give it to you because it went bad, explain to them your situation it may still be under warantee
Old Mar 27, 2011 | 04:47 PM
tritonman2001's Avatar
tritonman2001
You might also be able to match it up at advance auto, they have some stuff like that on the performance shelf.
