1.7 rockers???
Old Mar 26, 2011 | 11:07 PM
mean green 91's Avatar
mean green 91
1.7 rockers???
i have a 90 f250 4x4 5spd with a 5.8 from a 95 f150. its got some pacesetter shorties. would some 1.7 rockers be a good idea for this motor? would i need different valve covers?
i also heard that this motor has a roller cam. does that mean it operates with roller lifters?
Old Mar 27, 2011 | 07:10 AM
lew52's Avatar
lew52
Yes the 95 will have a roller cam with roller lifters , the 1.7 RR are a good upgrade for that motor , you may have to remove the valve cover baffles or use taller covers , not sure with the stock cam....Lew
Old Mar 27, 2011 | 07:26 AM
Conanski's Avatar
Conanski
Yes a roller cam means it has roller liters, and yes 1.7 rockers are a good idea IMO. I suggest you not remove the baffles inside the valve cover however and just "clearance" them where necessary.. meaning use whatever tool necessary(like a hammer) to produce the clearance needed so the rockers don't hit the baffles. FYI. These baffles covers the oil fll and PCV holes on respective valve covers and it's only the rockers directly below these that will potentially have any clearance problems, all other rockers will clear the stock valve covers no problem.
Old Mar 27, 2011 | 01:31 PM
mean green 91
nice. thanks for the input. theyre on the list
Old Mar 27, 2011 | 02:55 PM
mean green 91
how do you adjust the rockers once theyre in?
what kinda gains will i be lookin at? little better throttle? mpg?
Old Mar 27, 2011 | 04:15 PM
lew52's Avatar
lew52
There is no adjustment , non adjustable rockers , they just bolt down , a little more power , not sure if it will help mpg....
