351M or 300I6????
351M or 300I6????
Ok guys, I'm restoring my 78 F250, I have a 300I6 here at my house to go in it, but it came with a 351M.
I'm having a very very hard time finding the towers for the 300 for a 4x4 F250.. BUTTT the 351M original to the truck is at a rebuild shop being rebuilt now. I can probably get it back for about 800 to 1000 bucks.
Should I do the 300 for my low end pulling power on the farm
OR the 351M just because this truck has the chance of becoming my favorite toy to go show off in town, on the farm, or where ever I feel like it.
I am a high school student, this is my Jr year and I'm hoping to have it done to drive to my senior prom.. Kinda like the big unveiling... I'm not planning anything bigger than MAYBE a 35" tire for it. If that big... I want it to be loud and proud when I'm done...
The 351 would keep me from having to regear my axels... I imagine
They make similiar power. The I6 at a lower rpm. The 300 will get better mpgs than the 351m,but the V8 is going to sound better. It's all on what you prefer and whats most important to you. Sound or mpgs? There are upgrades for both, 400 crank swap in the 351 is well known. I'll probably offend some of the 335series guys but the 300 I6 will almost definitely outlast the 351m.
The mounts for the FE engine(360/390) from 73?-76 are the same as the 300.
But I have also been reading on here and the oil psi issues with the M's have me wondering how long this rebuild will last...
I also happen to know where SEVERAL good 460 cores are in my junkyard... But I do want to afford to drive it some... And a 460 under my *18 year old* foot... Mpg's? What's that?
I'm trying to figure out where this is any different from the 300....The 300 comes from the factory with timing gears, no chain. It has seven main bearings, and if you swap in an offenhauser intake with a holley 390 CFM carb and a set of headers you will wake up the 300.
Add to that the fact that the 300 routinely outlasts any of the V8's by about 2x the mileage, and the 300 makes it's torque at a much lower RPM, and I'd have to say the 300 is a better engine choice. Especially when you figure in the gas savings.
Well my only problem is I can not find the towers for the 300 for my 78... Add to the fact that I would have to fab up a hydro clutch system for it, and the fact that I would have to drop even more $$ to rebuild it and the 400 starts sounding a lot better for a "budget build" along with the fact that I have the linkage, bell housing, and almost everything for the clutch on the 400 in my shop...
