Getting ready to delete the EGR cooler and replace the oil cooler, aslo clean turbo while I'm in there. Should I expect a different EOT vs ECT spread when this is completed and are there going to be any new spreads to monitor oil cooler pulling?
I am puking from the de-gas bottle. I bought the truck with 136K on it and spoke with the previous owner. The truck was totally stock and in mint condition. I am hoping the motor is good and the EGR cooler is the problem. Since I am doing the Egr cooler delete I am also going ahead with the oil cooler as a buddy has a brand new OEM one cheap. At least I will know the status and hope the heads are good and the problem is resolved.
IMO, If your goin in that far I really recommend getting studs, new head gaskets, and have the heads checked before re-installing everything. You will hate yourself if you go to all that work and the head gaskets have let go. More than double the work for something that should have been checked earlier.
Fallguy- The problem is I don't have the cash to pull the motor and buy the studs at this time. I figured with the milage it was going to be due sooner or later and hope that it has just started to fail the cooler now and the heads are fine.
The fill line is actually below the minimum mark. It might be puking because the coolant level is too high. Make sure you don't have it overfilled. Mine will puke until the coolant level is 1/2 inch below the minimum mark on the degas bottle. Once it gets down to that level no more puking...
