Sponsored by: Real Truck
7.6mpg!!!
Old Mar 26, 2011 | 05:53 PM
JJf250's Avatar
JJf250
7.6mpg!!!
i had a missfire in cylinder 2 so i replaced all of my plugs with motorcraft plugs as well as cylinder 2's coil. i also replaced i iac and cleaned my massairflow sensor. now im only getting 7.6mpg i normally get 10.6mpg. any help as to what the problem is is very appreciated
Old Mar 26, 2011 | 09:20 PM
Pro DIY's Avatar
Pro DIY
Fuel filter?
Old Mar 26, 2011 | 09:22 PM
FireMe's Avatar
FireMe
Did you clear the memory in the PCM after doing the work?
How long did you drive it with the misfire? If you drove too long you may have burned up the cat.
