Sponsored by: Real Truck
4x4
Old Mar 26, 2011 | 03:00 PM
GeneLaw1's Avatar
GeneLaw1
4x4
Good people,
2006 F250 4x4 here. I was wondering what is the difference between 4x4 High, and 4x4 low? The instruction manual didnt really shed much light on it for me.
Cheers
Old Mar 26, 2011 | 03:16 PM
azgard's Avatar
azgard
4Low increases overall gear ratio giving more effective torque, while also significantly lowering your max speed. Don't ever use it on pavement.
Old Mar 27, 2011 | 09:22 AM
GeneLaw1's Avatar
GeneLaw1
Thanks! So I guess for offroading, probably best to use High unless you really need the extra torque?
Old Mar 27, 2011 | 10:11 AM
dchamberlain's Avatar
dchamberlain
It sorta depends on your point of view and conditions. Low gives you a lot more torque. It also slows you down a lot, letting you crawl over rough terrain without beating the crap out of your truck.
Old Mar 27, 2011 | 11:49 AM
5.4f250sd's Avatar
5.4f250sd
Its a lot easier on the tranny while going through gumbo or lots of snow
Old Mar 27, 2011 | 12:15 PM
azgard's Avatar
azgard
It's really a situational thing, most of the time you won't ever need to worry about using it, last and first time I ever had to really use it was to pull a truck out of a mudpit up a 30%-40% grade
Old Mar 27, 2011 | 02:11 PM
bigwhite7.3's Avatar
bigwhite7.3
4lo
4x4 high is for going regular speeds, daily driving in bad conditions. 4lo is for crawling slow, think of bike gears. 1st gear is 4lo, makes it really easy on the trans and motor to pull heavy stuff, offroading with big tires etc...
Old Mar 27, 2011 | 02:25 PM
1buzzbait's Avatar
1buzzbait
just make sure you use em both periodicaly when the situation allows----just like anything else, if ya dont use it-yewl loose it!!
Old Mar 27, 2011 | 03:35 PM
bigwhite7.3
heh
hehe
Old Mar 27, 2011 | 03:43 PM
FI460's Avatar
FI460
I use 4low a lot while hunting. When you're going down something steep you can kick it in 4low and save your brakes.
