33" tires ?
Old Mar 26, 2011 | 01:57 PM
White Boy's Avatar
White Boy
33" tires ?
i have a 1977 ford f250 2wd and i have 33" tires for it..my question is do i need a lift kit or just a leveling kit to use these tires..or nothing at all
Old Mar 26, 2011 | 02:21 PM
montana_highboy's Avatar
montana_highboy
Only you can answer that, but generally speaking you don't have to do anything to run 33's, but sometimes there are variables involved such as tire width, wheel offset and spring sag that may affect tire fitment.
Old Mar 26, 2011 | 02:50 PM
AK FORD GUY's Avatar
AK FORD GUY
Remember, he is talking about a 2wd, 33's might be a bit big for stock.
Old Mar 26, 2011 | 06:58 PM
White Boy's Avatar
White Boy
So it looks like I will need a lift to use these tires. They are 33x12.5. 16.5 rims
Old Mar 26, 2011 | 08:00 PM
Kalve's Avatar
Kalve
Hey white boy same here I got a 74 F250 2wd an plan to put 33" on it. Mine are 285/75/R16 & was told it might be tight for sharp turns an things like that. I am looking at a 2" lift on mine to be on the safe side.
Old Mar 26, 2011 | 08:05 PM
White Boy's Avatar
White Boy
Yea I might do 3" just to be on safe side. But all the lifts I see for my truck. Say will not work on trucks with the steering box close to firewall. And I won't have my truck for another 3 weeks so I don't know yet where it is
Old Nov 28, 2011 | 06:29 PM
PEARLOFTHEDESERT's Avatar
PEARLOFTHEDESERT
33x10.5x16.5 will rub the fender on dips and turns a bit. im actually looking for a simple lift for the front. only about 2 or 3 inches just to keep the fender off the tires.
Old Nov 28, 2011 | 10:37 PM
76Hauler's Avatar
76Hauler
AUTOFAB my friends!! They have a nice 3" econo lift perfect for 33's
Old Nov 28, 2011 | 10:43 PM
PEARLOFTHEDESERT
76hauler, i see you posting a lot of good things about autofab.
Old Nov 28, 2011 | 10:55 PM
jgavac's Avatar
jgavac
The guys at les schwab told me that with a 2wd, you should be able to go to 12.5 wide before tire rub. And PEALOFTHEDESERT, my 31.5x16.5x10.5's have no problems with rubbing
Old Nov 28, 2011 | 11:04 PM
76Hauler's Avatar
76Hauler
they are definately worth a look. Thay can be "pricy", but well-well worth it!
Old Nov 28, 2011 | 11:16 PM
Pickupmanx2's Avatar
Pickupmanx2
I have run 285/75/16's on a 67 F250, and a 73 F250 & F350,, on 16x8 rims,,, ummmm,, standard offset,, I think is 3.75"? So I would say yes, you could fit them,, might rub a tad on a mid-turn bump...
Old Nov 30, 2011 | 06:21 PM
PEARLOFTHEDESERT
jgavac, i had 31s and they were perfect for the truck, but i cant find any tires that size that fits the 16.5 wheels!! its depressing..
Old Nov 30, 2011 | 07:35 PM
jgavac's Avatar
jgavac
I think Irok and some other heavy off road companies make tires for 16.5 wheels... only problem is they are somewhere around 38-40 inchers. Way to big for a stock truck
Old Nov 30, 2011 | 09:13 PM
PEARLOFTHEDESERT
i know BFG makes 33's and 35's for the 16.5 too. i got 33 bfg's on my truck now and they suck. I need to get 15's and forget all the bs that comes with the 16.5. anyone else have a problem with any other wheel smaller than 16.5 wont fit? i think its the caliper screw but not sure..
