1985 351 Strange Problem
Old Mar 25, 2011 | 07:03 PM
mikeymadness's Avatar
mikeymadness
Hi,
I am having a problem which seems to stump everyone so I figured I would post, thank you in advance for any suggestions:
1985 F250 351 4V 4x4 automatic, manual choke carb.
Truck starts up fine and will run forever, however as soon as you shut it down it will not start again unless you let it sit for greater than 6 hours. It is getting Gas as I can see from carb and even tried manual pouring in. It also seems to be getting spark as I can generate a spark.
Nothing I have tried so far works, engine turns over fine but will not fire unless you let it sit. Its cool after a few hours but that is not enough.
Mike
Old Mar 25, 2011 | 07:35 PM
Ken Blythen's Avatar
Ken Blythen
Everyone will suggest the ignition module (which is a common failure) - but I have experienced a dying coil which would maintain ignition until switched off, then need a complete cool-down to restart, even with some spark at the plugs, as you describe.
Old Mar 25, 2011 | 07:41 PM
billt28's Avatar
billt28
X2 with Ken
Old Mar 25, 2011 | 08:05 PM
mikeymadness
Thank you, I guess I can start replacing coil, than move on to spark module which I am guessing is located on inside of Fender.
Mike
Old Mar 26, 2011 | 08:05 PM
eriklane's Avatar
eriklane
Problems
I'd also suggest the distributor pickup stator in the bottom of the dissy. But check it first per the manual with your meter.
Old Mar 26, 2011 | 08:09 PM
Sw1tchfoot's Avatar
Sw1tchfoot
You could also try checking the compression when it is hot and compare the readings to the cold readings.
