Project "Chuck Norris Cadillac"
So you're just using one piece of pipe up front for a tank? That won't cause air to move through the tank to the other side when turning and cause body roll? I would have though it would be better to have one tank per bag.
I'm with you so far. Yes I was comparing them to Firestone load helper type bags, so thanks for the explanation.
I will be using a tank, electric air compressor from extremem outback, and manual air valves. I will only have 2 valves, one for the front and one for the rear.
everything is all parallel. The top bars are shorter than the bottom bars to get my antisquat where is needs to be.
Even with a panhard bar, its not going to hinder me all that much. From full bottom to full top, the axle is only going to move side around 1/2'' or so from center to the left or right. Since at the standard ride height the panhard will be exactly parallel to the ground so there will be minimal play side to side.
You know just as well as I do that to each his own, and both triangulated and parallel 4 links are different, they both do the job. This is just what I happened to choose.
and yes to each there own
Yep, i'm not going to be going through the full 11'' of travel on the bags like you are either I'm pretty much only going to have mine set where I need it and ocasionally lower it to hook/unhook from trailers etc. I just thought that since i'm running as big of tires as I am, and have a built motor. The parallel and a panhard setup will have a little less stress on the joints and bars bc the top bars aren't having to act as a panhard as well.
The front shocks came in today. Today I got the front and rear axle brackets all done. Tomorrow I'm going to get everything measured up for the shock mounts and panhard bar and get the spring suspension out from under the truck. Sunday I should have most of it made and painted. The joint ends from ballistic will be here monday and I'll make the link bars and panhard bars then and get them painted depending on what time they get here monday.
I'll have some more pics posted up by sunday night hopefully
Clear view under the truck lol
I torched off my old trac bar brackets, cleaned the axle with a wire brush on a grinder, primered and painted the axle.
Brackets partly bolted up with bag
Here is the top mount and shock mount with the Bilstein 5150 shocks i'm using. 2 in the rear and 4 in the front.
Here is the rear panhard bar bracket, it goes from one side of the frame to the other on the inside, I still have to drill my holes in for the joint end. 2'' schedule 80
I would have gotten alot further today, but I was tied up for quite awhile, I had to go help dad move a bunch of cabinets. But I'll work in the rain tomorrow and have it done it a couple of days, the front wont take much time, should be able to do it in one full day.
#28
That was going to be my question. Wouldn't limiting straps be a better idea? How strong is the shock or shock bolt compared to the weight of the truck or axles?
#29
The shocks are pretty dang strong, and thats how every system like this I have seen is designed. In the front I will have 4 shocks so I'm not really worried about it. I will be using 5/8'' bolts through the eye of the shocks, and the top bracket has (2) 1/2'' bolts holding it on, the bottom is welded.
#30
