Steering box replacement
i noticed that the pitman arm is strange and it has the ball joint inside of it instead of the normal way with the joint in the center link.
I got the castle nut and cotter pin out, but I cannot seperate the pitman arm from the center link. I put a pitman arm puller on it and I almost broke it with the amount of force I put on it. Since the center link is at an angle to the ground the puller wants to move. I hit the arm with a hammer nothing seems to break it free. I wanted to try and re use the pitman arm to save money but at this point I don't care if I have to torch it off!! It seems impossible because the pitman arm is rigid with the steering box and the center link seems not to have any give. I cant just remove the arm from the steering box because Ford thought it would be great to put the frame x-member directly below the box.
Are there any tricks to remove the box? I must say I'm pretty pissed right now, and just looking for some advise.
Also there is a plastic cone that covers the intermediate shaft pinch bolt, which seems to be made in two pieces, which I can't seem to figure out.
In my 88 F-150 I was able to change my steering box in less than an hour. Sometimes I miss owning a 2wd trucks, there much easier to work on, I also miss the twin I-beam suspension, to me seemed much stronger and durable in my opinion.
Thanks for any help in advance.
