annoying warning beeper
Old Mar 25, 2011 | 08:24 AM
datsun147's Avatar
datsun147
Question annoying warning beeper
Hi all, I just bought a 1996 ranger and i have this annoying beeper that goes off after i start it i unhooked the wire at the seat belt looked for 1 at the emergency brake but couldnt find 1. sometimes the beep stops after about 5 mins but comes back on after turning a sharp corner. it sounds like it is coming from the dash in between the glove box and heater control does any 1 have any idea what it is, where i can find it and unplug it? Thanks for your help
Old Mar 25, 2011 | 01:50 PM
Rangerman Stan's Avatar
Rangerman Stan
Try looking up under the bottom edge of the dash behind the heater control area. There should be a couple of small (1 & 1/2 inch square) plastic boxes together that are white or gray in color. One is the beeper that has a two or three wire plug going to it that you can unplug. Let it beep when you go to unplug it so you can tell if you got the right one.
Old Mar 25, 2011 | 08:49 PM
datsun147's Avatar
datsun147
thank you stan I will look at that tomorrow
Old Mar 25, 2011 | 09:00 PM
FireMe's Avatar
FireMe
Are you sure it is for the seatbelt and not for the airbag system? If the airbag warning lamp fails in the instrument cluster, the restraint control module will sound a beeper instead.
Check and make sure the airbag light comes on when you first turn the key to the "Run" position.
Old Mar 26, 2011 | 12:01 PM
datsun147's Avatar
datsun147
I searched behind the heater controls and the raido no little boxes of any kind there also there is no air bag light on the insturmant panal im not even sure it has a air bag the steering wheel says it has 1 but there is not 1 on the passenger side i took that panel off too. where might i find this restraint control module? ive searching so much now it sounds like the beep is coming from every where.
Old Mar 26, 2011 | 12:34 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Are you sure the beeping isn't coming from behind the passenger kick panel? My son's 95 B2300 has this same annoying beeper, and there's no air bag light visible. The beeps are coming from behind the kick panel.
Could it really be as simple as the air bag light needs a new bulb? Wish I had known that before I pulled the cluster out to replace dash light bulbs, all but one was burnt out......
For reference, I get 5 sets of 5 beeps, then it shuts up. For about an hour, when it repeats the 5 x 5 beeping.
Old Mar 26, 2011 | 01:40 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i had an explorer do the same thing. had no air bag light either. pulled the cluster, replaced the bulb..all is well. the bulb is actually part of the system that checks itself every start-up.
Old Mar 26, 2011 | 03:07 PM
Rogue_Wulff
Was this the 5 x 5 beeps like I described? If so, I guess the cluster is coming back out to replace that bulb. Sounds much easier than ripping out the kick panel, and taking a sledgehammer to that beeper. It is THAT annoying.........
Old Mar 26, 2011 | 04:02 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i cant remember if it was but it was a series and would keep going over a period of time well driving.....very annoying, i'm well aware of how annoying it is lol
if your not getting an airbag light on startup, then thats what it is for sure.
Old Mar 26, 2011 | 04:10 PM
Rogue_Wulff
Thanks!
+Rep for that!
Old Mar 26, 2011 | 06:26 PM
datsun147's Avatar
datsun147
Thanks for the info the cluster comes out tomorrow and if that isnt it im going to find that sledghammer
Old Mar 27, 2011 | 01:12 PM
datsun147's Avatar
datsun147
Ahhh the silence is golden i changed the air bag light bulb and the beeping stopped. but the light the light does not go out it blinks in a series of 4 blinks pause 2 blinks pause then starts over but the blinking light is alot less annoying than that beep. Any ideas on what would keep the light blinking? Thanks so much for the tips on how to stop the beeping!
Old Mar 27, 2011 | 01:47 PM
Rogue_Wulff
The light is giving you a code "42" for the air bag system, I'm guessing. Sorry, no clue what that means......
Old Mar 27, 2011 | 02:41 PM
datsun147's Avatar
datsun147
ok update after blinking the 4- 2 , 5 times the light will stay on and burn steady no wonder it burnt out. all in all its better than that beep
Old Mar 27, 2011 | 10:45 PM
Rogue_Wulff
Well, I guess if the light does this on my son's truck, I can always stick some paint on the bulb. Anything would be better than that dern bleepin' beepin'.......
