Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Compressor break in oil
Old Mar 24, 2011 | 10:08 PM
v8xploder's Avatar
v8xploder
I just bought a 80 gal sanborn compressor, and on the way home in my bronco (i had it on its side) all the oil that came in it factory leaked out luckily it all stayed in the bag covering the motor. What should I use as break in oil? Just synthetic oil like the manual reccomends after the break in period or is the break in oil something different?
Old Mar 24, 2011 | 11:32 PM
fixnair's Avatar
fixnair
There is nothing special about breakin oil. In compressors it is the same oil what you would change it to. They call it breakin because after running it a few hours they want you to drain out all the dirt and contaminates that got in there during assembly. You can replace it with the synthetic that the manufacturer recommends or you can put regular hydraulic oil ISO 32. I personally would use the cheap hydraulic oil. It will last you for years.
jack wamp
Sep 27, 2011 10:32 AM
Gr8ride
Sep 25, 2009 02:49 PM
moosesp
2009 - 2014 F150
Feb 16, 2009 07:05 AM
Munch
Jun 12, 2006 08:54 PM
