You will need
a D60 from a 95-97 F350
Trac bar, trac bar bracket.
F350 leaf springs
F350 front driveshaft is optimal but not entirly necessary
If the F350 d-shaft is used, you will also need the t-case front yolk from a F350
You can use a 85.5-94 d60 but you will need to use the calipers from the donor axle
Looks like I'll have to stick with the twin I-beam,$1300.00 for Monobeam versus $350.00 for L/H I-beam. I'm going to attempt to straighten & weld the one I have.
Thanks Butch
Thanks Butch
Where are you that they are charging 1300 for a d60
