Reprogram 99+ Keyless Entry to 92-97 Keyless Entry
Old Dec 24, 2002 | 02:59 PM
JW 4x4's Avatar
JW 4x4
My truck is a '95 Ford F-350 4x4 XLT with factory keyless entry. My brother just recently sold his '99 Ford F-250 4x4 Superduty with factory keyless entry, and kept one of the remotes. Is it possible to reprogram the '99 remote to work on my '95 Ford F-350? I ask this because the '99 remote looks different than my '95 remote, and I have no other use for this remote than reprogramming it. Thanks for any help?
Old Dec 24, 2002 | 08:38 PM
steve83's Avatar
steve83
I would guess so, but I don't remember the procedure to reprogram the RKE and I'm not at home right now. If you don't get any more replies, remind me and I'll get it off the '96 service CD.
Old Dec 25, 2002 | 12:52 PM
JW 4x4's Avatar
JW 4x4
*Bump* Thanks for anyone who can help me Merry Christmas:-X12 :-X12
Old Dec 25, 2002 | 10:07 PM
steve83's Avatar
steve83
Programming, Electronic Door Lock Control Processor
Note:
The remote entry features will not function when the key is in the RUN or ACCESSORY position.
To unlock the driver's door, press the UNLOCK button on the transmitter (which is programmed into the remote entry receiver module) once. This will also disarm the anti-theft system, if equipped.
To unlock all doors, press the UNLOCK button on the transmitter twice. The second depression must be within five seconds of the first UNLOCK depression.
If more than five seconds have elapsed since the first depression of the UNLOCK button, pressing the UNLOCK button again will only unlock the driver's door.
To turn on interior lamps (13776), press either UNLOCK or PANIC.
To lock all doors, press the LOCK button on the transmitter once.
To confirm that doors have locked, press LOCK button again, within five seconds of the first depression. This will beep the horn (13832), flash the parking lamps and lock all doors again.
To activate the personal security alarm, press the red PANIC button. The horn will beep and parking lamps (13201) will flash for a maximum of two minutes, forty-five seconds.
To deactivate the personal security alarm, press the red PANIC button again or turn the ignition switch (11572) ON.
Note:
The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The remote entry receiver module can store up to four transmitters in memory.
To program (or reprogram) transmitter(s) into the remote entry receiver module, perform the following steps:
1. Turn key to the ON or ON/ACCESSORY position and momentarily short the two terminals of the program connector (C4) (a two-pin connector taped to the wire assembly connected to the remote entry receiver module, approximately 6 inches from the remote entry receiver module). All doors should lock then unlock. Remove shorting pin.
2. Press any button on transmitter. All doors should lock then unlock to verify that the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
3. Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
4. Key off. All doors should lock then unlock.
5. Check operation.
The two-pin programming connector has a White/Yellow and a Grey/Yellow wire.
Old Dec 27, 2002 | 04:33 PM
JW 4x4's Avatar
JW 4x4
[updated:LAST EDITED ON 27-Dec-02 AT 05:34 PM (EST)]Well, the 99+ remote did not program to my keyless entry (92-97), so I guess I have one remote for sale for a 99+ Ford F-Series with a brand new battery. If anyone is interested please contact me through email. Thanks for your help!
Part # F87B-15K601-AA
FCCID: GQ43VT11T
CAN. 1470 102 326
Old Dec 27, 2002 | 04:49 PM
slave2dafords's Avatar
slave2dafords
Old Nov 9, 2009 | 02:10 PM
DeathRowe's Avatar
DeathRowe
Does anyone (Steve83, JW 4x4) have a picture of the 2-pin connector that you have to short out? I got a 96 F150, and the little black keyless entry module has a sticker on it with a date of 12-7-95. Ive been looking for this connector for 2 days and haven't found anything. I also tried the turning-the-key method which doesnt work, so im guessing i have to use this connector method. Please help!
Old Nov 9, 2009 | 02:25 PM
quicklook2's Avatar
quicklook2
someone suggested earlier in one of your other threads on this same topic for you to go to dealer and ask one of the older service people.
still the best avenue.
