Help removing manifold bolts
Old Mar 16, 2003 | 10:33 PM
boris's Avatar
boris
Hello....I am currently replacing a 300 6 cylinder motor in my 1987 F150 pickup and cannot get the exhaust bolts out of the y-pipe to get the exhaust disconnected from the manifold. Could someone give me some advice!!! Thanks
Old Mar 17, 2003 | 04:32 AM
dk5122's Avatar
dk5122
1" cut wheel w/drill. I used a sawzall to get mine off. Took about three metal blades it was a pretty bad angle to get to.
Good luck, Dan
Old Mar 17, 2003 | 07:57 AM
steve83's Avatar
steve83
Lots of Liquid Wrench, and vibration. Don't just twist steadily - you'll shear the studs. Unscrew a little, then screw them back in & rinse with LW. Then unscew a little further. Eventually, they'll come out.
