ICP troubles
Old Mar 21, 2011 | 05:38 PM
Unrealo4's Avatar
Unrealo4
ICP troubles
04 f550 117500 miles truck runs rough but it always ran. Today it wouldnt start after lunch. Well it does start but dies within 5 seconds. I unplugged the ICP and it started and ran like always. I replaced the ICP with a new one from ford. Still won't start with it plugged in. With it plugged in it throws a p2614 & p2617. It is also throwing a p0273 which is another story. Anyone have any ideas? Harness maybe?
Old Mar 21, 2011 | 06:04 PM
npccpartsman's Avatar
npccpartsman
This is an 04 motor, right?
I would start with harness chaffing. Try under the intake hose at the passenger side valve cover or in that area. To me it sounds like it's potentially a V-ref problem but that's a guess on my part. You might check V-ref for a short to ground also.
Old Mar 21, 2011 | 06:17 PM
cheezit's Avatar
cheezit
unplug injector #5 amd see what happens. IMO failed injector coil shutn ya down.
als try disconnecting the ebp
Old Mar 21, 2011 | 06:29 PM
Unrealo4's Avatar
Unrealo4
Truck does still start with the ICP unplugged. Plug it in and it just dies or won't start. Ill try unplugging #5 tommarrow morning and look for evidence of chaffing.
Old Mar 21, 2011 | 06:31 PM
npccpartsman
Didn't know a failed injector coil would do that. Interesting.
On a side note.....normal fan RPM's at idle cold and warm if there is such a thing?
Old Mar 21, 2011 | 06:32 PM
cheezit's Avatar
cheezit
yup been down that road before.
if its not #5 pick another one and try it.
Old Mar 21, 2011 | 06:36 PM
Unrealo4's Avatar
Unrealo4
Fan seems to be running normal. It did have a bunch of codes after they ran the batterys down trying to start the truck. One was fan speed sensor, which never came back after she was charged and cleared. It also showed like a random misfire code on number #5.
Old Mar 21, 2011 | 06:39 PM
cheezit's Avatar
cheezit
imo you have a bad injector. more then likly the screws poped off the spoolvalve and the coil is shorting. and possible cam and crank codes from not starting.
I would think that maybe you have a 2291 code as well but palying with the icp sensor may be hinding that.
Old Mar 21, 2011 | 06:43 PM
npccpartsman
The fan question was for Cheezit--LOL. Sorry.
cheezit's Avatar
cheezit
tim no set fan rpm.
Old Mar 22, 2011 | 09:54 AM
Unrealo4's Avatar
Unrealo4
Dead on cheezit! Unplugged #5 and it fired right up with the icp plugged in.
Old Mar 22, 2011 | 07:13 PM
cheezit's Avatar
cheezit
thanks for the update ~
Old Mar 22, 2011 | 07:48 PM
Unrealo4's Avatar
Unrealo4
Here's a pic about just how dead on you were.
1 injector 2 parts and like welding slag all over the spool valve.
Old Mar 22, 2011 | 07:50 PM
cheezit's Avatar
cheezit
looaround the top side of the cyclinder head and try and find the broken bolts. Ive never had one get sucked up before but there is a first time.
and thanks for the pic.
Old Mar 22, 2011 | 07:51 PM
cheezit's Avatar
cheezit
by the way whats make the truck shut down is the back feeding of voltage when the coil shorts out.
