Transmission options?
Old Mar 21, 2011 | 04:44 PM
bigdavesohc's Avatar
bigdavesohc
Like all the other highboys around here, I have the np435 4 speed. I would love to put a 5 or 6 speed behind my FE. Are there any options? If it means swapping to a 429/460 or a small block, I would rather not.
Thanks
Old Mar 21, 2011 | 04:58 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Aftermarket options are as many as the 429/460.
The 5 or 6 speed I would look at Richmond, TKO, or Tremtec, and I would buy the best one you could possabley afford.
If you have the "modern spread on your bellhousing you may be allright, but if not theres FE car bellhousing available that work.
You may have to go to a hydraulic clutch set-up too.
I looked into this becouse I wanted a T5 for mileage, but I have the old style bellhousing. So its no-go for me. I will have to cheap out, and do a C6 swap with a new rear gear.
The cost for a decent T5 varient was over $3500, and all the way up to $6000 for the "best of the Best" type 6 speed. I can do a C6, and rear end for under $500 if I have some good luck to about 1300 if I don't.
Old Mar 21, 2011 | 05:09 PM
bigdavesohc
how do you tell about the "modern spread"? Getting a new bellhousing would not be an issue. I would love to have a nv5600 behind a well built 390. Granny first AND double OD- mouth watering...
Old Mar 21, 2011 | 08:19 PM
Ziegelsteinfaust
My old style bell housing the bolts are in a square fashion.
Modern the top 2 bolts are wider then the bottom 2 by about a inch per side.
I also think the NV's have cast in bellhousings. So you'd have to use an adapter, but I only know of them for autos.
fisherman_chuck
Jul 11, 2019 10:35 AM
Texasknowhow
36
Jan 3, 2015 10:55 AM
anthony myrick
Large Truck
Aug 27, 2014 06:58 AM
88_F0RD
Mar 31, 2014 08:55 PM
Fire57
Large Truck
Feb 10, 2014 01:05 PM
