porting efi manifolds
Old Mar 21, 2011 | 01:17 PM
octaneforce's Avatar
octaneforce
i have a brand new set of efi manifolds that im going to be putting on my truck to replace the cracked leaky ones. has anybody ever tried porting these things? just a crazy thought.
Old Mar 21, 2011 | 04:50 PM
Harte3's Avatar
Harte3
The only "porting" that might be done is to remove any ledges sticking out in the down stream flow. Make a pattern of the exhaust ports with a light peice of cardboard, place it on the manifold(s) and wherever the manifold sticks out into the exhaust port openings of the pattern, remove that area to fit the pattern and blend/taper it into the manifold.
Old Mar 21, 2011 | 07:53 PM
F-250 restorer's Avatar
F-250 restorer
Interesting subject. I would think that what Harte3 said would certainly help, as would cleaning up the entire manifold ports with a 120 grit wheel.
Old Mar 22, 2011 | 06:39 AM
octaneforce
hmmm. ill have to get a hold of some sort of grinder. all i have is a few 4 inch makita grinders and maybe a knock off dremel hanging around.
