Sponsored by: Real Truck
Power Windows
Old Mar 20, 2011 | 01:49 PM
1ford1's Avatar
1ford1
Power Windows
1999 F250 SD, quad cab. Passenger side power window quit going up, will go down from either door, just not up. I have hooked a spare car battery to the motor harness, works up and down. I pulled the motor from the passenger door and plugged it into the drivers door harness, goes up and down from the drivers door switch. I have tested resisitance at the switch, found resistance off of one terminal in the up mode and found resistance on one terminal in the down mode. I have voltage at the switch and at the motor harness from the switch. Can anyone tell me what I should be reading on my volt meter at each terminal? Or any other suggestions would be appreciated.
