miss off idle
Old Mar 20, 2011 | 12:57 PM
rdweathers's Avatar
rdweathers
miss off idle
74 390, just change intake, cam, and headers. I now have a miss off idle and will go away as it speeds up. My compression readings are 1 at 102, 4 at 105, 2 at 110, and 1 at 111. The wet test is 4 at 110, 1 at 115, and 3 at 120. Is my engine too wore out to handle the up grades? It ran fine with the stock 2 barralel, intake, and exhaust manifolds.
Old Mar 24, 2011 | 08:11 PM
lonnie1952's Avatar
lonnie1952
Could it be possible to have some Gasket material in one of the cylinders ? Slightly fouling a plug ??
Pull the plugs and check them or replace
Maybe a piece of carbon is fouling a plug at idle
Possible vacuum leak ?
Lonnie
Old Mar 25, 2011 | 06:18 AM
rdweathers's Avatar
rdweathers
I am now thinking my cam or lifters are bad due to the oil not having the zinc properties, i used lube when assembling the parts but have since learned if you do not use an oil additive you may have problems.
Old Mar 28, 2011 | 02:15 PM
The Great Jose's Avatar
The Great Jose
I had a similar problem. After some research, I found out that FEs are NOTORIOUS for misfire due to spark jumping between the #7 and #8 spark plug wires.
Checking the separation of those two wires might be something to look at.
Old Apr 3, 2011 | 04:31 PM
rustywheel68's Avatar
rustywheel68
Can you describe your symptoms in a little more detail?
I'm wondering if what you are describing is a fuel or electrical issue. Maybe the accelerator pump shot isn't enough, now that you've upgraded the internals?
Have you already drained the oil since the break-in? If so...did you see a lot of metal?
Old Apr 3, 2011 | 06:42 PM
rdweathers's Avatar
rdweathers
I replace the intake gasket and that was about 90% of the problem the rest is with timing and carb, no miss now.
Old Apr 4, 2011 | 07:44 PM
jchamp429's Avatar
jchamp429
Good deal, congrats.
scbird
16
Jun 28, 2015 06:49 AM
tbm3fan
23
Aug 2, 2014 07:58 AM
XLT2.5L
1983 - 2012 Ranger & B-Series
25
Aug 24, 2009 07:08 AM
jwtaylor
36
Dec 23, 2003 09:15 AM
mustange70
Jun 13, 2002 12:48 AM
