Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape Vaccum Diagram
Old 03-18-2011, 07:49 PM
guliver's Avatar
guliver
guliver is offline
Does anybody have the Vaccum Diagram for a 2001 Ford Escape V-6? Where is the MAP Sensor located?
Thanks
Old 03-19-2011, 06:45 AM
tomw's Avatar
tomw
tomw is offline
The diagram is supposed to be on the radiator support or on the underside of the hood. I found it to be on the underside of the hood of a 2007, to the left of center.
You will not find a MAP sensor on a 2001, I don't think. I believe all systems were switched to MAF sensors prior to that. The MAF would be in-line from the air cleaner to the throttle body.[where the throttle plate is located] All the air going to the engine for combustion passes through it.
tom
Old 03-19-2011, 05:16 PM
cheff1315's Avatar
cheff1315
cheff1315 is offline
Unhappy Vacum Leak
What can i do to find out if i have a vacum leak,or were it may come from on a 01 escape?
Old 03-19-2011, 11:17 PM
blupastu408w's Avatar
blupastu408w
blupastu408w is offline
Is the check engine light on? If so, go to your local parts store and have them pull the code(s). What symptoms are you having? Usually a vacuum leak will cause an overly high idle and overly lean fuel mixture (which would throw a code and set the check engine light).
These engines don't have a lot of vacuum lines, so a leak usually occurs where the intake plenum bolts to the lower intake... or where the lower intake bolts to the head. If either have ever been removed, a new gasket is required (according to Fords 3.0L Durotec Engine Repair manual). The old gaskets are not meant to be reusable. I've reused them without issue, however. As well, if they were not tightened and torqued in the required sequence, the plastic intakes warp easily.
Just some ideas - I'm interested to hear what symptoms you're having.
~Jason
racer5569
1997 - 2003 F150
02-25-2017 10:27 AM
stinger57
Nevada Chapter
12-20-2016 08:26 AM
Carmax
09-27-2015 06:55 PM
classic4x4
06-16-2015 09:29 PM
countryboy24381
1983 - 2012 Ranger & B-Series
10-03-2012 06:08 AM
Quick Reply: 2001 Escape Vaccum Diagram
