C4 & rear ratios & RPM's....
From what I can find....it appears the "stock" ratios in the C4 transmission are:
2.46:1, 1.46:1 and 1.00:1… reverse is 2.19:1
Of course...just about anything between a 2.03:1 to a 2.89:1
1<SUP>st</SUP>-gear ratio is available aftermarket.
<O</O
Anyway...with a 3.89 ring & pinion...and 15" tire/wheel combo
around 28" diameter this calculator shows it'll be spinning 3268 rpm...
FORDMUSCLE.com webmagazine - Gear Ratio / Engine RPM Calculator
Does this "seem" sorta high for cruising the hiway on an extended
trip ?...
Just kinda rethinking some things...seems to be winding a little tight
for a LONG roadtrip.........
Time to start looking for an AOD????
<O</O
trip ?...
Big-Sarge
6.7L Power Stroke Diesel
47
01-17-2024 10:32 PM
bismic
08-10-2015 10:35 AM
