Optimum hitch height is dependent on the trailer. The trailer should be relatively level when hitched and normally loaded.
You can set the trailer with the jack so the frame is parallel to the ground and measure the height of the ball pocket. Add a little height (maybe an inch) if you expect your truck to squat much.
