sterling 10.25 and 10.5
i had a question on the sterling axles in the 88-97 3/4 ton and 1 ton, i noticed 92 and older are a short shaft and 93 and newer is a long shaft up to the 07 10.5. i want to convert my 88 10.25 to a super duty 4 bolt flange but it is a long spline and mine supposably a short shaft does anyone know how much longer the long shaft yoke is compaired to the short shaft. is there any way there is enough threads on the pinion to bolt a long spline yoke to the axle
i'm not entirely sure what you are asking here, but it seems to me that you are wondering if you can bolt a 93 and up pinion yoke to a 92 and down pinion? from what i have read you have to replace the pinion and the yoke for that to work. I could be wrong. hopefully someone will chime in and we can figure out the answer.
badasssapper67
05-01-2016 08:00 PM
hairyboxnoogle
11-24-2012 06:31 PM
tjbeggs
13
11-22-2006 08:20 PM
