ok got new ip hooked up and i brock down and got a epump to blead it out the thing is the epumps huming away and i have fuel at the feul flitter head but know out of the injector lines plz help if i dont get it out of the drive way to knight my moms gona put it in nutrul and let it rool in to the street so she can get her harley out of the graege
is the feed line hooked up and tight? If so then make sure there is fuel at the return line sticking out of the top elbow, that should be radiator top side of the IP and going to some kind of return line. If it is getting fuel then good, you just need to loosen all the injector lines. If it doesnt have fuel, then loosen the black hex head fitting on the passenger side aft of the fuel screw plate towards the firewall, once you have fuel flowing there, tighten up and it should be fine. had the same problem. A dry pump is a pain in the ***.
is there an obstruction somewhere? is it hooked up correctly? does the FSS click when you un plug and plug it back in? Seems there is something else going on here. Sounds terribly like lack of power to the fss and if it doesnt have power, it wont prime.
Just fixed a guys truck that did the same thing. Now I don't know why you changed the pump but this is what happened to him. He couldn't get it primed up. I ran an electric pump from a bucket of fuel to the pump it ran fine. His problem was the fuel tank switch the whole time. It was sucking enough air to give him troubles and when he changed the pump it wouldn't prime up. Just an idea. You new pump could be junk also.
i hope its good the fuel ffs dose click and the the tanks switch is bypassed i run start lines to the lift pump with a epump for priming fuels going in to it just not coming out
If you have clean good fuel going in and you have fuel coming out of the return then it has to be the pump. New/ used?
the fuel gos in it just dosnt want to come out to the injectors i get i dripel out og the one on top going to the return lines dose it matter that i turned the ip up to flats befor i put it in
it dose it clicks i took out the hex bolt im gona let the epump pump for awhile
my epumps primed it with that bolt open in two seconds, awhile shouldnt be too long. Careful not to rupture the mechanical fuel pump diaphragm, if i read your post correctly by using the electric.
it isnt getting to the return side, joe are you priming with the key on? just curious. Trying to eliminate the obvious.
no that wont affect the priming, its something else. all of the injector lines are loose while cranking????
only one was lose and cat the two flats was in prep for my banks turbo and it was 2/6 for a full turn like the banks manuel i ran a jumper to fss dint make a diffrence key is in and i have power to the ip
