Injector Question
Old Mar 17, 2011 | 06:07 PM
F350_Todd's Avatar
F350_Todd
Injector Question
Let me first say thanks for all the great information I have obtained from this forum. So I had the water pump go on my 2000 F350 and was replacing that and figured since half of the front of the motor was off I would check the injectors and glow plugs and do the 50 cent fix. I have been having a tough time starting over the winter and already replaced the GPR which helped alittle but didn't solve the problem completely so I figured the UVCH was probably loose. When I Ohmed the passengers side all looked good. When I Ohmed the drivers side the glow plugs looked good but 3 of the four injectors were around 11 ohms. I took the driver's side valve cover off and the UVCH was loose as shown in numerous pictures on here. I pushed in the harness and put my cut quarter in. When I ohmed the connector again it only reduced the questionable injectors by a few ohms (between 8 and 9 ohms). So here's my question. I read that the injectors should be less than 5 ohms. How bad is it if the injectors are showing 9 ohms? I checked them several time and they are consistantly around 9 ohms. I am getting the shuttering that has also been described when the UVCH is loose. I have not had any check engine light though. Thanks and be safe.
Todd
Old Mar 17, 2011 | 07:35 PM
tdpower's Avatar
tdpower
I would replace the VC gasket and harness on that side. You can ohm them directly at the injector but may be hard to do w/o a pigtail. I think the valve cover harness/gasket are interchangeable with the other side so you could try that as well.
Old Mar 18, 2011 | 11:06 PM
F350_Todd's Avatar
F350_Todd
tdpower, thanks for the adivse. Turned out to be the wiring harness. Made it to the dealership 5 minutes before closing today. Hopefully will have truck back together this weekend. Thanks again and be safe.
Todd
