Offroad & 4x4
4x4 problem f250
Old Mar 16, 2003 | 01:07 PM
billys's Avatar
billys
4x4 problem f250
when i engage the 4 wheel drive it runs fine straight, but the truck does not want to turn at all.
Old Mar 16, 2003 | 07:55 PM
steve83's Avatar
steve83
4x4 problem f250
Do you have an aftermarket differential or any axle modifications? What tires are you running? Lift?
Old Mar 16, 2003 | 07:57 PM
RCrawler's Avatar
RCrawler
4x4 problem f250
We need more info about the year, drivetrain mods.
Does it make noise when you try to turn? You can't physically turn the wheel, or you can turn the wheel but the truck goes straight?
Jason
Old Mar 16, 2003 | 10:55 PM
billys's Avatar
billys
4x4 problem f250
it is a 2000 F-250 crew cab short bed. there is a 6 inch lift with 37 bfg bajas. there is no other modifications. the steering wheel will turn, but the truck will barely turn. it almost feels like the tires are rubbing but there not.
Old Mar 16, 2003 | 11:14 PM
RCrawler's Avatar
RCrawler
4x4 problem f250
Check the steering linkage for looseness. Check the steering box and the shaft for looseness and being attached to the frame. Double check all of the u bolts, and shackle mounting (anything that was loosened for the lift kit installation) Have somebody turn the wheel back and forth while you watch the steering and suspension for play.
Was there any steering correction done with the lift kit, such as a drop pitman arm?
Jason
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
