F-53 "V10" Chassis
F-53 "V10" Chassis
Hopefully this will be a good place to start, 2011 F-53 Chassis.
Need recomendation on oil & changes for a hard working V10.
I'm from old school "pay-me-now-or-later" so I need help.
GCWR-30,000, brand new
change engine oil, 1st @ 500 miles, w/filter
changes after @ 3,000 miles, w/filter
oil type 15W-40 ?which brand?
filter type ?largest capacity?
transmission (auto 5-speed)
change oil @ 15,000 miles, (?filter type?)
change after @ 50,000 miles
filter every 2nd change
rear end (6:13)
same as transmission mileage (above)
?which brand & type?
Please, any information & input appreciated.
rear end (6:13)
Same truck engine but just on a large frame truck. I'll assume theres a manual in the vehicle to tell all the proper fluids if not we'll help you.
For wondering minds want to know what a F53 chassie is page 39and 40 of this pdf. It also has all of the 2011 Ford line of trucks with spec and misc, Good read.https://www.fleet.ford.com/truckbbas...ok-rwj_V17.pdf
I had a Motorhome that was a on an F-53 chassis with the V-10. Drove that thing more miles that I care to think up 6 percent grades and very hot temps around Gila Bend AZ and Yuma. Pulling a jeep and fully loaded for 6 years, nearly daily, as I was working out of it. But, I changed the oil at every 3k-5k religiously. Never more than 5k. I do not see why you could not use full synthetic. I used 5w20 Motorcraft, sythenthetic blend, used Motorcraft Filters and checked the oil daily. Transmission, if its the 4R100 change the fluid every 15K. I had to replace the tranny, in Albuquerque, what a PITA in a Motorhome. There is a place called Statkus Engines. They cator to RVers and Racing Heads. The biggest headache that I encountered was somewhere along the line someone put Green Anti-Freeze in with my orange. It gelled and stopped up the radiator. I limped home, took out the radiator and had it rodded. Took the thermostat out of the block and just let water run thru the block for hours. Then I flushed the tap water with distilled, over 20 gallon. Then filled 50/50 with GREEN. Drove another 3 years without a hitch and hard driving. There were days I drove over 900 miles in that thing pulling the jeep and full of equipment and supplies. I worked on Indian Reservations in the Southwest, so I had to be prepared for most anything.
dntsdad
Modular V10 (6.8l)
01-02-2024 11:42 AM
Cyclonus
07-09-2017 01:45 PM
Brian Goodman
19
06-01-2016 12:23 PM
Cornell1
1997-2006 Expedition & Navigator
13
09-26-2012 08:36 AM
