I've had an intermittent problem with my cruise control on my SD in my signature. On long interstate trips and after the cruise has been engaged for a while, the truck shutters and the cruise control disengages and the ABS light comes on for no apparent reason. This occurs while traveling on flat interstate at approx 70-80 mph. When I engage the cruise right after this happens, it works but the ABS light stays on. The ABS light stays on until I stop and turn the truck off for a short while. Other than that, the truck seems to be running flawlessly.
I recently had the computers reprogrammed due to a fuel gauge problem, but this had occurred several times before the reprogramming.
I am on the road traveling up north as I write this and will not be able to take it to my dealership until I get back in 4 days. Anyone have this problem before?....Any ideas of what may be causing this problem? Thank you in advance for any and all input.
