351w 5Speed?
Old Mar 16, 2003 | 11:31 AM
stover007's Avatar
stover007
351w 5Speed?
Did ford ever have the 351w in a F150 with a manual tranny?
Old Mar 16, 2003 | 01:07 PM
5x5F150's Avatar
5x5F150
351w 5Speed?
Not sure about the F150 but have a F350 in front of my house with that e/t combo, so I can't see why not....
Old Mar 16, 2003 | 04:07 PM
EPNCSU2006's Avatar
EPNCSU2006
351w 5Speed?
They put the ZF behind the 5.8 and 4.9 in '88 F150's only, not sure if any other transmission was used in other years.
Old Mar 16, 2003 | 05:06 PM
GDIBronco's Avatar
GDIBronco
351w 5Speed?
No, it was the ZF's. No others. They went into HD F-350's and I think F-250's. Should have no problems mating one up if you are swapping.
Old Mar 16, 2003 | 09:58 PM
EPNCSU2006's Avatar
EPNCSU2006
351w 5Speed?
Ford put them in the F150 in '88 only. 250's and 350's all other years from '88 on with the 4.9 & 5.8. From 87 on with the 460's and diesels. http://www.zf-group.com/pdf/lightTru...sion_Chart.pdf
Old Apr 10, 2003 | 02:23 AM
ford_diesel1986's Avatar
ford_diesel1986
351w 5Speed?
1987 on up zf-542 5 speed were put with f-150-f350 combos and they go like 6.9 and 460 had same bellhouseing but the diesel has a adapter plate and the 300 302 and the 251 all have the same case to it but the zf 5 speed from a 2 wheel drive wont work in a four wheel drive with out changing the rear half of the transmission
