6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
LiveWire IAT2 reading???
Old Mar 16, 2011 | 10:35 PM
xplict's Avatar
xplict
Hey, I have the LiveWire setup with the senor display running. My question is what is the IAT2 reading in this picture.
The sensor itself I have removed and cleaned, as it was very sooted up, and after reinstall its still reading these low numbers between 16 and 23.5.
WOT, boost at 42psi up to 90mph the IAT2 reading does not go above 23.5?
Is that saying its reading temp incorrectly, or is it displaying something else. The temp here is 32F currently
Any info is greatly apprecitated. Also is it possible to have the LiveWire display in Celsius
Old Mar 17, 2011 | 06:36 AM
senix's Avatar
senix
It is a resistor that senses the intake air temp and provides that info to the PCM. What values it should read at I am not sure.
Sounds like it is bad.
Old Mar 17, 2011 | 05:48 PM
cheezit's Avatar
cheezit
iat 1 will be hotter then iat2 till the engine is running. the reason for that is the maf has a heated element.
iat 2 is used in conjuctin with the egr system. iat2 goes up when egr is flowing.
bizzelj
Feb 5, 2015 04:54 PM
ol-blu
Feb 1, 2014 07:57 PM
Robs06SuperDuty
Sep 6, 2011 09:33 PM
