Yeeeeeehaw
Old Mar 16, 2003 | 09:52 AM
02superstroker's Avatar
02superstroker
Yeeeeeehaw
well, got my 54/78 chip on friday, installed it yesterday and WOW! Truly makes it feel like a completely new truck. Easy install and awesome improvement. Just one question... occasionally when i am in the 78hp mode and really step on it the "service engine soon" light comes on. I looked in the manual for what this ment, and it basically said that there could be an emmision control failure. Has the happened to anyone else? Is there a problem or is the emmision crap just that sensitive? thanks
Old Mar 16, 2003 | 10:13 AM
FTE Ken's Avatar
FTE Ken
Yeeeeeehaw
That will happen occasionally with most any higher HP tune. It means the turbo boost is higher than the factory pre-set range.
Old Mar 16, 2003 | 10:42 AM
xanthias's Avatar
xanthias
Yeeeeeehaw
There are some easy solutions out there for this. There is a nifty replacement MAP sensor line with a pop-off valve and sensor port built right into it. As I understand it, the pop-off will prevent you from getting this trouble code.
