need help 302 gurus please...
Old Mar 16, 2011 | 02:32 PM
insane_goofball's Avatar
insane_goofball
I'm heading out in 4 days from Detroit to the Florida keys...
I have a 95 f150 with 302 and automatic.
I have replaced the following
plugs, wires, coil, tps, mass airflow, cap + rotor, IAC, o2
the TPS and IAC came from o'reily's the rest is from autozone.
the problem is this. 500 to 1000 RPMs it runs ROUGH. at speed its fine. Albeit a bit sluggish.
at a stoplight it gets very rough, and 40% of the time it stalls.
the truck is running very rich (fuel) and getting bad mpg.
it has the original fuel filter. and I plan to replace it tomorrow.
does anyone have any ideas what would make it run so rich and want to stall? the voltages on the TPS are not 100% for what Ford calls for. but close to spec. Do you think I should get rid of o'reily crap and try AZ or NAPA for a TPS?
I have set the timing yesterday.
I replaced the mass air flow yesterday, but... when I unplug it... idle does improve. so it acts like mass airflow was not reman correctly.
any help would be GREATLY appreciated before my rode trip. lol
Old Mar 16, 2011 | 02:41 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Sorry for getting offtopic here, but did you buy those ground effects for your truck, or is your truck a special model (Mark III), etc?
-Wes
Old Mar 16, 2011 | 02:48 PM
Conanski's Avatar
Conanski
The first step in diagnosing an engine operational problem with these trucks is always the same... pull the codes.
Old Mar 16, 2011 | 02:50 PM
Kapusta's Avatar
Kapusta
How did it run before you changed everything you mention? Have you tried to see how it runs with the old IAC, TPS & O2 sensors. It almost sounds like an O2 sensor issue above all else.
Old Mar 16, 2011 | 03:33 PM
lew52's Avatar
lew52
I would have a look at the fuel pressure regulater , remove the vacuum line , if theres any fuel in it , replace it , also like above , pull the codes....Lew
Old Mar 16, 2011 | 03:43 PM
cjben's Avatar
cjben
Lew beat me to my suggestion. lol
Old Mar 16, 2011 | 04:38 PM
insane_goofball
#1 you can buy the body kit and roll pan anywhere, but it came that way. Show Trucks USA conversion.
#2 no fuel in vac line for fuel pressure reg.
#3 no current engine MIL after mass airflow swap.
I had o2 reading lean (rich fuel lean o2 level)
and TPS Low voltage not what expected or lower than expected.
those were the only 2 codes that showed up. but I have no engine light on currently.
It acts at idle like a bad or sticking IAC, poor throttle response like a bad TPS.
I have also run 1/2 can of seafoam in each gas tank. and used another can on a vac line on intake.
Old Mar 16, 2011 | 05:38 PM
insane_goofball
forgot to mention...
my charge gauge is normally at the A - L of normal. and when it acts up, it bounces around. and I do get a bearing sound under the hood when giving it gas (replaced idler and tensioner when those died)
and I know the engine coolant temp sensor is bad as well. that gauge is flatline at the bottom. But, being OBD1 I don't think the ECT would play a role in the idle issue. but... I'm much more famil with carb or OBD2 systems. not that strong with drivability on OBD1 systems.
Old Mar 16, 2011 | 09:35 PM
Conanski's Avatar
Conanski
You don't need a CE light to get codes, and if you still have TPS and fuel table codes(what you're calling O2 codes) then that's what you fix first.
Old Mar 16, 2011 | 10:18 PM
Nealcrenshaw's Avatar
Nealcrenshaw
Go exchange these parts for motorcraft it does make a difference.
Old Mar 16, 2011 | 10:34 PM
bren_tx's Avatar
bren_tx
and fuel pressure.
original filter? i would replace that asap.
have a helper rev the engine, then use a broom stick and touch different parts of the engine while holding to your ear and you can pinpoint where the bearing noise is coming from.
the ECT has a lot to do with the fuel mixture, i.e. when the engine is cold the computer will tell it to run more rich.
Old Mar 17, 2011 | 05:06 PM
insane_goofball
swapped out o'reily crap. running better. changed ECT as well.
don't have a pressure tester for fuel.
i couldn't get filter loose, so I took it to a shop, they said lines have been replaced with braided steel and they did not have a tool that could get it loose. So, I'm going to CUT the line with a tubing cutter and replace both spring clip sides with rubber lines.
Just sounds like a have a bigger cam in it. no longer attempting to stall like before. bouncy idle... between 550 and 850.
Old Mar 17, 2011 | 08:39 PM
mturnbull50's Avatar
mturnbull50
Check for any vacuum leaks. Also make sure that your MAF is clean. The hotwire style MAF does not do well with contamination, or vibration for that matter. If you are running an aftermarket, oiled cloth (K&N style) filter, ensure that it is not oversaturated, which could in turn cause the MAF to become contaminated. Also, spark timing is computer controlled, so timing set at the distributor is not the same as with a regular points or hei style distributor. Set the distributor to the factory specs, check for any vacuum leaks, change the fuel filter, double check the MAF for contamination and stock compatability, and see where that takes you.
Old Mar 17, 2011 | 09:11 PM
timbersteel's Avatar
timbersteel
I had a similar problem, 'cept mines SD. If your charge gauge is going funky, you may want to pull the alternator just for grins and have a parts house check to ensure it's working correctly. It's a free service and if it's never been checked since you have owned it, then I would get it checked. It helps keep steady voltage with the battery acting as a huge capacitor. If it's failing it can affect how sensors read their input.
Was just a thought since I would have a MIL/CEL come on when it started acting up and different sensors showed to be failing.
BTW> As other Posters mentioned..Stick with Motocraft
Old Mar 17, 2011 | 09:14 PM
ostrx250's Avatar
ostrx250
yep i bet you got a vacuum leak got a spray bottle and mist the hoses one at a time and listen for the idle to smooth out and inspect those darn little plastic lines and handle with care
