Heres what the plan is for my build.
Holley Truck Avenger EFI
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
Edelbrock Alum Heads
Roller rockers.
Short Block:
Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
Based on the Xtreme Energy Hydraulic Series
Intake Lobe 5443 and Exhaust Lobe 5203
(Specs:268/280 adv., 224/230@.050, .524/.544 lift, 110 LSA)
Compression around 9.5:1
Stock crank
Stock rods with good bolts
Standard volume oil pump
Stock oil pan with windage tray
Hedman Headers to wider exhaust
4 inch lift
Ranger Overdrive Unit
35" tires
Is this a 351 or 460? I'm a fan of alum heads and Edelbrock has a great rep. Most people I know use a high. Volume oil pump, but I'm not sure the pros/cons.
