Rear brake question
Old Mar 16, 2011 | 12:49 PM
StevenhF100's Avatar
StevenhF100
Rear brake question
Can you swap the bigger rear brakes off a 73-79 on to a 65 rear end? I have a 65 dana rear end that someone replaced one of the backing plates with what looks like one off a newer 73ish rear end. Obviously it doesn't work right with the 65 brakes and drum, but can you replace both sides with the newer backing plate, shoes and drums and have it work right?
Old Mar 16, 2011 | 04:10 PM
daveengelson's Avatar
daveengelson
Don't know if any help; bookmarked this thread quite awhile back, may be additional info; suggest run search on topic and narrow search field to 61-66 forum.
https://www.ford-trucks.com/forums/2...e-upgrade.html
Old Mar 16, 2011 | 04:47 PM
StevenhF100
Thanks, that was exactly the information I needed!
