Front fuel pump gave out
Old Mar 16, 2011 | 12:20 PM
bchapman75's Avatar
bchapman75
I have a 1997 F350. I just lost the front fuel pump. Before I drop the tank or remove the bed, I was wondering if there are any relays or switches that I should replace. I would rather spend a little time trying to fix something small than having to deal with the pump just to find out it wasn't the pump after all. Thanks for the help.
Old Mar 16, 2011 | 01:12 PM
rla2005's Avatar
rla2005
Fuel Selector switch on the dash is the device that switches power between the two pumps, as well as fuel level signal. The Fuel Pump Relay is common to both, if one works then that is not your issue.
