Need help!!! E40D problems
Old Mar 15, 2011 | 10:43 PM
93idi7.3's Avatar
93idi7.3
Ok i have a 93 f250 4x4 7.3 idi with a E40D trans (rebuilt about 35,000 miles ago). My problem is when i shift into reverse 2or 3 sec after i do so it shifts really hard into reverse n make a clunk sound. It does it very slightly when i put it in drive. The trans also sqeels when i give it gas in reverse but not in drive, but when i driving my truck takes a long time to shift between 2nd 3rd n 4th gears unless i let off the gas for a sec. There is a little extra fuild in the trans also, would a flush filter n the rite amont of fluid stop all this or am i look at buying a new trans thx for all ur help
Old Mar 16, 2011 | 01:04 PM
93idi7.3's Avatar
93idi7.3
no one has any ideas
Old Mar 16, 2011 | 06:49 PM
93idi7.3's Avatar
93idi7.3
Ok i did some investion today n found out its not my trany that is chunking when i put it in reverse its my rear driveshaft turning bout a quarter turn before it pressure on the rearend gears
Old Mar 16, 2011 | 06:53 PM
93idi7.3's Avatar
93idi7.3
Oh n i forgot to mention that i had a set of welded spider gears in the rear end but i changed it back to stock
Old Mar 19, 2011 | 12:26 AM
bustech81's Avatar
bustech81
the welded rear end would not have any effect on shift timing, a little hard on axle shafts though. If all the shifts are late and harsh, look to the throttle position sensor. Sometimes called a FIPL switch(fuel injection pump lever). There is a procedure to set it through a scan tool but if your shifts are late, retard its position a little bit and go drive it. Make little minor adjustments until its right.
Old Mar 19, 2011 | 10:31 PM
93idi7.3's Avatar
93idi7.3
Theres no spot to hook up a scaner
Old Mar 20, 2011 | 12:24 AM
bustech81's Avatar
bustech81
Yes there is, if it has an E4OD that is. Look along the left hand inner fender. It will be a OBD1 ford connector. I would just slow down the TPS switch though, that's the easiest.
Old Mar 20, 2011 | 12:37 AM
93idi7.3's Avatar
93idi7.3
Nope no obd1 connecter all there is a eec test connecter on the driver side i even asked advance to scan it the other day they said that it has to be a 94 n up. I didnt believe them so me and a friend took 2 hours looking for one n no luck we looked under the dash n all inside the engine bay
Old Mar 20, 2011 | 01:03 AM
bustech81's Avatar
bustech81
The EEC connector is what you're looking for. Has kind of a wierd shaped main connector with a single wire with it?
Old Mar 20, 2011 | 02:47 AM
93idi7.3's Avatar
93idi7.3
Ya but i never seen one like that before i didnt know that was it
