Sagging Suspension question
Old Mar 15, 2011 | 09:22 PM
calialx1's Avatar
calialx1
I have a 1994.5 Ford F250 with the 7.3 trubo and 5sp. When looking at the ttruck from the front, the tires look like this /-\ with negative camber. Is this due to worn out leaf springs? or bushings? My leaf springs have a negative arch and the truck is raked (I know this is normal though)
What is the best way to correct the problem?
edit: truck is a 4x4
Old Mar 15, 2011 | 10:08 PM
Conanski's Avatar
Conanski
These trucks tend to do that especially if you backup and stop, but if the front tires are still tilted in after pulling forward that is a sign the springs are sacked, so your options are add-a-leaf or new springs.
Old Mar 15, 2011 | 10:13 PM
calialx1's Avatar
calialx1
Will adding another leaf make the ride significantly stiffer?
Old Mar 15, 2011 | 10:19 PM
Conanski's Avatar
Conanski
Yes adding a leaf often does that.
Old Mar 15, 2011 | 10:34 PM
calialx1's Avatar
calialx1
well I hope its not drastically stiffened, I am going to go with this:
Add-A-Leaf Kit-RH2
Old Mar 15, 2011 | 10:38 PM
Conanski's Avatar
Conanski
The diesel is the heaviest engine available so while it puts the most load on the springs it should also ride a little better than most.
Old Mar 15, 2011 | 11:00 PM
court1100f's Avatar
court1100f
Paul my 1990 F150 Extended cab has the same problem All the time I know it needs Tie-Rods but would that resolve it or would the springs also need replacing the truck in question you've already helped me out extensively with it's the 2wd with 300 sorry for adding my question but it's the same exact question but in 2wd Form
Thanks in Advance
Courtney
Old Mar 15, 2011 | 11:56 PM
calialx1's Avatar
calialx1
^^ I believe tie rods will only help you with toe in or out, but not the camber issue you state having.
Another question: I noticed there is some play in the steering wheel, I would say holding a finger on the top of the steering wheel, I can roll it over about 2 inches before there is a direction change. Is this something I can adjust? or would I need a new steering box?
