Power Door Lock Button....
Old Mar 16, 2003 | 12:05 AM
e_no_g's Avatar
e_no_g
My power door lock button on the drivers side doesnt work for the Unlock function. Its a 98 xlt, any ideas?
Old Mar 16, 2003 | 09:38 AM
PrPlayboy's Avatar
PrPlayboy
Has water gotten into the switch? Could be that the switches internal connector and dirty. I would pull the door panel off (If you know how to) and tack the switch apart. If your not comforatable with taking the switch apart I would see how much a new one is. They shouldn't be to much $$. Do you have a multi mater? You can see if power is going out of the switch when you press the button. If it's not the switch or a loose wire it is the electric piston (for get what they are called) (attuater?).
Old Mar 16, 2003 | 09:59 AM
Trent109's Avatar
Trent109
i had the same problem with my 93 explorer, i went to the junkyard and got some different switches, and now it works fine!
Trent
Old Mar 21, 2003 | 03:54 PM
Ken2600's Avatar
Ken2600
My 97 has the same problem. The driver's side button won't unlock.
I just haven't pulled my door panel yet since they always seem to rattle or something after you remove them.
