steel wheel?
Old Mar 14, 2011 | 07:52 PM
kupiec20's Avatar
kupiec20
steel wheel?
looking at pro comp steel wheel with a load rating of 3100lbs
would that wheel work?
Old Mar 15, 2011 | 03:14 PM
powerstoked!'s Avatar
powerstoked!
what pro comp steel wheel are you looking at that is rated for 3100lbs? I did a crapload of research on rims when I bought mine and never saw a steel wheel rated over 2200...
Old Mar 15, 2011 | 03:21 PM
powerstoked!
well i'll be... just researched it, you must be looking at the series 52? Supposedly rated for 3400lbs... don't see how they could do that but... you might want to check with them that that isn't a typo because I the only steel rims I have seen rated like that are military rims and they were heavy as heck. The 2.5" backspacing will more than likely be an issue though, you will rub your tires on the firewall and bumper when turning most likely
tractormanbill
Dec 24, 2016 03:59 PM
gbkeith
Dec 1, 2016 09:37 PM
darrin900
Oct 14, 2016 04:47 PM
ufvj217
Sep 25, 2016 11:39 AM
pgr380
2009 - 2014 F150
22
Jan 17, 2014 11:25 AM
