quick pyro help
Old Mar 13, 2011 | 11:20 PM
91dirtydiesel's Avatar
91dirtydiesel
quick pyro help
i need to know if these would be good locations. non turbo 7.3. Im thinking these spots just because of the easy location. yes or no??
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=manifold.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/manifold.jpg" border="0" alt="Photobucket"></a>
Old Mar 13, 2011 | 11:21 PM
91dirtydiesel
if not one of those spots then where would you guys??
Old Mar 14, 2011 | 03:00 AM
Aune163rd's Avatar
Aune163rd
I put mine here when I had the turbo installed....btw guys...the banks Turbo I bought for 300 dollars is in and i have it turned up 2 flats....and the pyro/boost/and tranny temp guages are in! Hits 12lbs boost if i get on her.
Old Mar 14, 2011 | 03:04 AM
91dirtydiesel
Congrats!! Glad it works good for ya! I installed pyro in location I posted
Old Mar 14, 2011 | 03:07 AM
Aune163rd's Avatar
Aune163rd
Thanks, good to hear, what is it reading so far?
Old Mar 14, 2011 | 09:14 AM
snaponprofile's Avatar
snaponprofile
I didn't want to tap my manifold so I just tapped the crossover on the drivers side about 5 inches away from the manifold. It should be close to as accurate as yours, Dave S. always said to tap it right after cylinder 8.
Old Mar 14, 2011 | 09:46 AM
91dirtydiesel
So far it idles at around 270 ish. I've went up a steep hill and got into it, I saw 850 then I backed off and it almost instantly went down to 400. I got a really long steep hill im going to try later on this week. I will let you know what it gets to. Now remeber I do have my fuel turend up with no turbo.
As far as the actuall drill and tap on the manifold, it was super easy. I did it right at the #6 cylinder (second to last driverside)
Old Mar 14, 2011 | 10:56 AM
snaponprofile
My tap was pretty painless also, but I had to get all the metal shavings out or they would mess my turbo up. Its nice will n/a cause they will all just fly out the tailpipe. It was just easier for me to make sure no metal shavings got inside by removing the crossover, tapping it, clean out metal shaving and then put back on the truck. If I had tapped the manifold, I wouldn't have had a way to get all the metal shaving out but if I was n/a, I woulda done it like you did.
Old Mar 14, 2011 | 12:36 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Wow that engine compartment looks clean and rust free!
Luckey sob!
Old Mar 14, 2011 | 12:40 PM
snaponprofile
i don't see aun's pic.
Old Mar 14, 2011 | 02:39 PM
wreckinball's Avatar
wreckinball
aune are you back from Iraq? you gotta post up a vid of that boost! Thats great man!
Old Mar 15, 2011 | 12:26 AM
GHeTTo JOe's Avatar
GHeTTo JOe
ok does drilling the hole in the manifold while engine running really work best to blow metal shavings out rather than letting them fall into the exhaust?
Old Mar 15, 2011 | 06:53 AM
snaponprofile
I would think that would just move the metal shaving along inside rather than blow them out.
Old Mar 18, 2011 | 08:52 PM
GHeTTo JOe's Avatar
GHeTTo JOe
so how about if you use a vacuum to get as much shaving out as possible then maybe crank engine over but no start? would just the compression from the starter kicking it over let the metal shavings pass safely?
Old Mar 18, 2011 | 10:37 PM
91dirtydiesel
I hear if u put vasoline on end of tip it will collect the metal shavings
