engine swap?
Old Mar 13, 2011 | 09:03 PM
precisionplumbing55's Avatar
precisionplumbing55
engine swap?
I got an 84 ford 4x4 with a 1979 ford 400 automatic tranny was wondering if a 351 windsor will bolt up to tranny and mounts
Old Mar 13, 2011 | 09:11 PM
bashby's Avatar
bashby
......no.....
Old Mar 13, 2011 | 10:35 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
might bolt up to the mounts (if they weren't hacked out for the 400) but you'll definitely need a correct 351w bellhousing style transmission.
Old Mar 14, 2011 | 06:56 AM
precisionplumbing55
engine swap?
Thanks i thought i better check before i buy this motor...
Old Mar 14, 2011 | 08:05 PM
cadunkle's Avatar
cadunkle
A 460 would be an easier conversion. Just need conversion mounts and it will bolt up to the bellhousing.
Old Mar 14, 2011 | 09:02 PM
precisionplumbing55
engine swap?
Appreciate the help on this, Thanks!!!!
Old Mar 16, 2011 | 11:00 PM
FoMoCo69's Avatar
FoMoCo69
the 351m/ 400 bellhousing will match a 429/460 big block but not a 351w. if you chose the 351w you will have to find a small block transmisson. a standard trans is alot easier because the bellhousing is removeable from small to big block with the new process 4 speed. just a thought. if i can help let me know.
