Need input from everyone fast
Old Mar 15, 2003 | 06:14 PM
ace324's Avatar
ace324
Did FORD have a problem in 1986 with the 351W motor. I read somewhere that around 200k alot of people have had problems with a serious knocking. Mine did it and I was just wondering it this was something ford had a problem wiht.
Old Mar 16, 2003 | 11:10 AM
HotWhlz85's Avatar
HotWhlz85
Ace, I've never heard a claim about any problems with a 351W knocking. Your question sounds like one you'd ask if this were something that is common to Ford products, the 351W specifically. But you do have to consider that with 200,000 miles on an engine, you've pretty much gotten the life out of it. Does it smoke? Do you have oil blowby? Sounds like time for a rebuild to me.
Old Mar 16, 2003 | 12:38 PM
pfogle's Avatar
pfogle
I have 135k on my 351, its starting so make some noise, but it's also time for an oil change. If it's a heavy knock it's a rod. If it's a little knock it could be a wrist pin on bearing, hows the oil pressure?
Old Mar 16, 2003 | 02:33 PM
ace324's Avatar
ace324
I have already sold that truck and the guy asked me what is wrong with the motor. I thought i had read on this website before about that problem with the bearings. the motor never used a drop of oil
Old Mar 16, 2003 | 02:38 PM
pfogle's Avatar
pfogle
All the bearings are, are a little piece of metal with a hole in it that keeps oil in and also provides a barrier between the crankshaft and the block.
