Possible Charge Issue?
Old Mar 13, 2011 | 04:50 PM
WH90's Avatar
WH90
i got an 80 F100 that still has its original alternator, but i was looking at the charge gauge and its moving to C when a full load is on heat, lights, it moves halfway to C, so i got my tester out with no load it reads 14 load at 12 at battery should i be concerned?, also the engine tried to run with the key off whats happening to my antique baby? Thanks
Old Mar 13, 2011 | 05:19 PM
Old Hickory's Avatar
Old Hickory
If it shows 14 volts at charge that is OK. If it keeps on running when the key is turned
off I would look at the idle speed and the timing. If the timing is to far advanced it can
cause run on.
Old Mar 13, 2011 | 08:14 PM
chrissmallwood's Avatar
chrissmallwood
Your run-on issue could also be from a sticking ignition switch. My switch started sticking and it tried to do that to me once.
